djengr »
https://forums.nicoclub.com/djengr-u32907.html
Sun Sep 07, 2014 12:25 pm
I am in the process of diagnosing a hard to start when warm on the pathfinder (starts great when cold or hot). Finally changing out a leaking rocker cover gasket. I was thinking a leaky fuel injector or maybe a couple of them leaking. Intake plenum had a heavy smell of gas. Pulled out the fuel rail and pressured the system. No leaks however there was fuel coming out of the fuel damper vacuum hose connection. I am 90% sure the damper is bad, but wanted to verify here.
Does this sound like a bad damper? This is a dealer item and will have to pick it up on Monday.
There is not fuel so far leaking from an injector nor the pressure regulator vacuum line connection.
thanks, just verifying.
David
2002 pathfinder, 140K miles, 4WD, 3.5 engine.
BTW, taking off the intake plenum is not hard, but tedious. Need band aids or smaller hands.
