2002 Pathfinder Foglight HID help
launcherville
Car: 2002 Pathfinder
So i have 2 HID kits, 10K for the head lights, and 3K for the fogs. Both ebay xentec kits(been buying these for years, cheap and awesome).
Anyways...I did not have any problem with the head light install, however I can not seem to figure out how to install the fogs. When I popped the stock bulb out there is one wire that I disconnected....the fogs have 2 wires?? Also not even sure how the H3 bulb will fit in the casing. I think i read on here that someone had to cut the back of the plastic?
If anyone has any insight or a link to a youtube clip(couldn't find one) that would be great.
Camelfilter
Car: 1999.5 Pathfinder SE
2009 Titan Pro 4X Crew Cab
The HID set I used for my fogs:
I drilled a large hole through the back of the plastic to fit the HID bulb wire through then used some silicone to seal it up.
I could have also drilled a small hole, cut the HID wires, fed the wires through the small hole, then spliced them back together.
I chose to keep the HID bulb wires intact with there respective connectors.
-By keeping the original connector for my fogs, I can allways switch back to regular H3 bulbs if I want.
iceman14n
Car: 2002 Infiniti QX4
look hard enough.. there are 2 wire connected to the bulb coming from the vehicle. its a different story that the bulb has one wire coming out, the other wire gets connected from the holder.
Now if you want to make the hole to bring the two wire in through the original holder, then you need to create a hole other wise you can just connect the wires just like you connected for the headlights.
