PathfinderRecalled »
https://forums.nicoclub.com/pathfinderrecalled-u209565.html
Tue Oct 09, 2012 11:18 am
My Pathfinder had a bad alignment and it appears the camber was way off for a Camber Kit to resolve the camber issue.
Anyone can help me or at least confirm this was the correct procedure for my bad alignment.
I noticed the problem with my tire wear on the passenger wheel it was showing uneven wear on the inner section. I replaced the front Struts and bushings at 95k. Then at 105k I replace the wheel bearings. Also I noticed the camber was off and my alignment was creating the uneven wear. The car has never been in an accident so the front end wasn't misaligned due to structural compromise but maybe a large pot hole or curb bump could have cause the issue. I took it to a cheap alignment shop and I was told this model had a fixed camber. They were able to adjust the Toe on the alignment but would need to do a more drastic measures to resolve the camber problem. I also called the Nissan dealership and they confirmed the car doesn't have any camber adjustment on the struts and I would need a Camber kit to fix any problems. The kit didn't work and the auto shop recommend to enlarge the holes on the struts to adjust the camber so the car can be aligned correctly. So basically they widen the holes on the strut mounts to address the camber issue. The car is align correctly now but I feel it may have compromise the suspension integrity. Has anyone had the same problem? Was this correct solution?
Thanks,
Pathy.
