2002 Pathfinder Bose Radio Pins Help
varnco
Car: 2008 Infiniti G35
I replaced the head unit from the 2002 with a newer Panasonic head unit.
However, I forgot to take the CD's out of the old 2002 Bose Unit. I don't want to take the dash apart, etc., so I figure if I can power up the old radio using a computer power supply for 12v, I can get them out.
However, I can't seem to figure out which pins on the back of the Bose radio are to power the unit on. I don't want to guess and short the radio out, as it was working fine.
Googled, and couldn't find it.. I found different versions of the wiring harness.... but nothing concrete and I don't want to make any magic smoke.
Any help is appreciated.
atraudes
Car: 2001.5 Infiniti QX4 4WD
I did the same thing when removing the trunk CD changer :facepalm2
I assume you're talking about the CD changer in the stereo in the dash, not the trunk one, correct? Check out EL-187. It looks like giving pin 10 of the M48 plug 12 volts (and pin 6 too, if that doesn't do it) will do the trick.
http://www.nicoclub.com/FSM/Pathfinder/ ... der/el.pdf
:luck:
