I suck at explaining things I think
First, back in late February or early March it started blowing full power regardless of the speed set. If you turned it off it blew through the floor full power.
Second, in March maybe? It quit all together and you could turn it on or off and it made noise like it was trying to work but nothing through the vents.
Then, I replaced that part and when I'm going over 25 or so I get cold, but very weak pressure air blowing. I can change the temps but it doesn't blow enough to cool the vehicle. The faster I go the harder it blows but still not anything enough to keep the kids in the back cool. When idling I get nothing at all.
Yesterday morning, when it was relatively cool outside (low 50s) it worked perfectly- blew cold air or hot air both in manual and auto every speed and every vent. It was working. Then I turned it off to see if it would still work (never turned the car off, this was during school drop off) and back to what it was since replacing that part.
Found the interior fuses today and pulled the ones i thought it could be according to the map. They looked fine through the window but the prong type things you put in look rusted/corroded.
Right now, when I turn on the air on manual I can hear something come on and it sounds all weak/sick and if idling I get nothing but it will cool or whatever I set the temp as if I'm moving, but not enough to cool the vehicle or really even keep me cool. It's not even blowing hot air. Auto gets nothing period no matter what.
I hope this makes more sense. Sorry, I'm a girl, and new to this whole diy thing with my car.
