2002 Pathfinder AC cold then warm
james62
Car: 2002 Pathfinder
Good afternoon. The Air Conditioning in our 2002 Pathfinder runs great with cold air some times and other times the air is barely cool. My auto mechanic has made some repairs, but the AC continues to alternate from cold air to barely cool air.
Any idea's, suggestions as to what could be causing the proplem and what one can do to fix it are all gratly appreciated!!
Many thanks,
Dyron Dinsmore
404.606.3220
Leo1998
Car: 1998 Nissan Pathfinder
What repairs did the mechanic do so we can eliminate them for a diagnosis.
jpullium
Car: 2002 Infiniti Qx4
2003 Nissan 350z
Have him check the thermostat. I had the same issue and my thermostat was acting up and causing the AC to kick off because of the faulty temperature reading the engine computer was receiving from the thermostat.
zach7685
Car: 2002 Infiniti QX4
2001.5 Nissan Pathfinder SE
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
Check the RPM when you don't have ac. My car wont blow cold air unless i'm moving or it idles correctly. If the car doesnt idle at the right speed it will cut out to protect the compressor.
NismoPick
Car: 97 Infiniti QX4
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
^^^ No offense but all these "checks" are just beating around the bush.
First, when it starts blowing warmer air, pop hood and look at the front of the compressor. Is it spinning or stopped?
Second, use a manifold gauge set to check the R134a high and low pressure at their ports. If the pressure is too high or low, the pressure sensor will turn off the compressor.
Third, are you full throttling (gas pedal to the floor) at any time? There is most likely a full throttle switch that turns off the a/c compressor at full throttle.
Forth, Please review and download the FSM: http://www.nicoclub.com/FSM/Pathfinder/2002_Pathfinder/
