miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Mon Mar 18, 2013 12:01 am
Taking the rotors off is not labor intensive at all... Especially for a shop which does brakes everyday. If i really wanted to try and get them off ASAP, both sides could have the old pads and rotors removed in under 15 min.
Resurfacing rotors is garbage, if your just replacing the parts with original spec equipment, what they charge you for resurfacing you can get new blank rotors for the same price and normal pads are cheap too.
This shop sounds trashy and personally if your not doing it yourself id take it elsewhere unless you already got the work done then bummer.
Even upgrading wont cost you much more, getting slotted rotors (dont get x-drilled because they warp easily and crack) stick with slotted or slotted/dimpled.
Right now on the pathfinder i think im at a new record with pads and rotors up front, i got ebc 3gd sport rotors for a good price 6 yrs ago (cant seem to find them that cheap anymore) and ceramic pads which sadly i forgot which brand they were but not cheapo, and the car isnt driven like a grandma either.
I have about 40% pad life still left give or take, no warping/shaking etc, brake dust is non-existant.
