mdmellott wrote: ↑Mon Jun 30, 2025 9:08 pm
The bolts for use with the aluminum covers are common hex-head flanged M6 x1.0 screws (Nissan/Infiniti part number 01411-00181)
Thank you so much, this is the information I needed!
For anyone from the future with the same weird problem as me who's looking for a concrete answer;
M6-1.0x30mm with 10mm heads. I ended up using AutoZone NeedaPart bolts, not the best in the world, but a hell of a lot better than the "mostly correct" Menards and Home Depot offerings. Bought them one at a time by going from store to store until I had enough of them lmao
With this info, I was able to find that they're 30mm, longer than the plastic cover's bolts because they need to clear the grommet. Turns out, I actually had 8 of them in my toolbox, I just didn't know what they were because I was under the impression I was still looking for a bolt with no threads on the top half, since that's what pops up on image search when you search the part number, the other thing that shows up is a screw which also wasn't correct.
It'll take me a while to edit the literal 500GB of footage I shot for this project (I could do an entire rebuild on a 2JZ and only end up shooting half that footage I s2g the VQ looks like it was designed by Germans), but you'll prolly get a shoutout 'cause this is legitimately the message that made it click like "I ALREADY HAVE THOSE!"
I'll update this thread when I'm done with the video.
It was really difficult to track down the other 12 I needed, for some reason. Home Depot was out of them, Menards only had ones with 6mm heads, even Fastenal doesn't stock them. Turns out, M6-1.0x30mm with a 10mm head is actually really rare. No wonder Nissan stopped making them, this must be the only thing they ever got used for.
Technically you could get the 6mm head ones that're more common, but when it comes to anything measured in inch-pounds, the difference in diameter might actually make a difference when distributing the force on the grommets. Plus, 6mm is a pain in the a** to remove later, if God forbid you have to do it twice for some reason.
