2002 Nissan Xterra
bobbiedoll44
Car: 2002 Nissan Xterra
I have a 2002 xterra v6 not 4wd. About 6 months ago my check engine light came on. Took it to auto zone and it threw 3 codes. One was P0328(knock sensor) One was P1444(canister purge valve solenoid)the other was P0453(they didnt give me a paper on that on so unsure) thet said that it could be just one of these causing all 3 codes. So in process of trying to find out what was wrong the check engine light went back off. I chalked it up to maybe bad gas or gas cap not being on correctly. Well a couple weeks ago the light came back on and my xterra will feel like its cutting out or surging for a bit. Its not constant and happens after its warmed up a bit. Anyone have any ideas? Cant afford to change everything that coded...
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Distributors are known to be problematic on the VG33s....bearings go bad in them. Is it falling on its face at higher RPMs or is this surging / cutting out in all RPM ranges?
I'd definitely start with ignition. Pull the distributor cap and see if it's rusty at all underneath. If so, that's a good sign you may have the bearing issue.
