Brunzy »
https://forums.nicoclub.com/brunzy-u194090.html
Mon Nov 21, 2011 4:18 pm
Like I posted above, I have my a 2002 Nissan Sentra that has a sputtering problem. I understand that one cylinder is not firing, as I have tracked the problem back to the wire harness. The boot has been switched between cylinders, and the number 2 cylinder still is not firing, while the others are still.
I'm wondering is this the wiring harness or could it be a sensor that has gone bad? Any help would be greatly appreciated.
Currently I do not have a code scanner, so codes are not going to happen.
