Yesterday, I have worked on this car all day. I've taken off, air intake, throttle body, IAC valves, EGR vavles, intake manifold. I was hoping that it would be a intake manifold gasket leak, but it wasn't. I've cleaned out real good with degreaser, carburator cleaner, and etc. once I have done finishing what I was doing, I started car back up, still the same problem. even replacing EGR valve temp sensor. btw, I have replaced plenum gaskets, EGR valve gaskets. have any other Ideas? I have ran out of mine. T.Tdjtorello wrote:Id take a look at your Idle Air Control Valve, and look for a vacuum leak.
That doesn't really work with vacuum leaks... only with pressurized leaks (like a leaky tire). The bubbles are caused by escaping air, but vacuum is sucking the air in, not pushing it out.spec_v03 wrote:try spraying soapy water on the lines and look for bubbles, if there are any, theres a leak there.
