Qxxx4 wrote:How much and where do you guys think i can get a set with rims in the GTA? do you think theyd look good on my black qx4? honest opinions, thanks.
I think it will look pretty good, they are still silver painted wheels, so it won't stand out like chrome or black.
The rims should fit no problem. Pathy/QX4 are the same platform, bolt pattern and essentially share the same wheel well, or at least very similar.
As for your speedometer being off, it will depend on the size of the tire, not the wheel. I mean the size of the tire on the Pathy wheels vs. the size of the tires your rig has stock. I am not sure the stock size for either rig, but I assume they are very similar.
You can use a tire calculator to see if they are the same. Google "tire calculator" and the Miata one is great.
For example, my 2001 QX4 takes a 245/65/17 stock, but with 16 inch wheels, it will be a 245/70/16. That is so close in diameter that it's only like .1 percent different.
I got a deal on my snow tires, which are 245/75/16, so the speedo is about 3 percent too slow. It's not that big of a deal to me. They are about an inch taller.
