2002 Nissan Maxima Door Panel Removal
siccs7
Car: 2002 Nissan Maxima
Needing to check internal switch/motor on driver side door..window intermittent roll up/down issues..need diagrams/pics/suggestions..thanks...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There's one screw in the bottom of the arm rest handhold and another toward the front of the door. The rest is just held in place by plastic clips. Pull or pry the door panel away from the door and the clips will snap free. They're reusable if you're careful. Sometimes they do break. Don't forget about the wire running to the door courtesy lamp while you're pulling on the door panel.The power window switch surround lifts out (held in place by spring clips) once the screw is removed.
(Click for high res)
siccs7
thanks 4 that info..now need 2 kno which wiring/switch im lookin at that controls driver side window...
siccs7
was able 2 isolate as alarm window modulator short, reconnected factory wiring and my window now rolls up/down consistently...
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Good stuff. Nice to hear it was a simple fix and not a bad regulator.
