jwerty1 »
https://forums.nicoclub.com/jwerty1-u123638.html
Wed May 27, 2009 2:53 pm
Front of engine , to the right, Look just under throttle body coming towards the front , Just above the thermostat housing there's 2 switches mounted there, The 1st one near the top closer to the throttle body is the cam/crank sensor, HOPE this HELPS
You are referring to the cam position sensor, mounted by the camthe crank sensor is mounted where i stated on my previous post
