2002 maxima nocking
baggle
Car: 2002 maxima se
hi i have a 2002 maxima se 3.5. i bought this car one year ago. last month i notice a knocking sound when i started the car. it only happens when the car is cold. and i notice that the oil pressure light blinks at the same rethome as the knocking. i decided to do a tune up and when i was changing the spark plugs one of the plugs was full of oil. don't have loose of power or any codes(check engine)...if i put a new valve cove for the spark plug leak would the knocking go away? i think that the knocking is because of the lack of pressure that is coming out of the valve cover. need some suggestions
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Have you checked your oil level? Is the car burning oil at all? You shouldn't lose that much pressure from a bad valvecover gasket. I'd definitely get the oil pressure tested, though, whether you do it yourself or pay someone.
