brickbox »
https://forums.nicoclub.com/brickbox-u269045.html
Sat Nov 11, 2017 11:16 am
I recently bought a used 2002 QX4 4WD with 143K miles on it.
It seems to have a vibration that I am unable to figure out why. I just had 4 new matching tires inflated to the same PSI installed yesterday. But the problem still persists.
Its very smooth until about 48 mph. Right around 50mph the vibration gets pretty bad. If I switch it from 2WD to Auto - the vibration goes away for a few minutes and then comes back. No change switching from Auto to 4Hi.
The vibrations feel the same if I engage/disengage O/D. Also, its the same if I shift out of "D" into "N".
In 2WD, the vibrations reduce at about 60 mph and is present at 80mph. It gets really bad at 85mph. If I switch at these speeds to Auto or 4Hi - then the vibration is pretty bad. Letting off the gas helps a little bit, but its still there.
I crawled under the car and the drive shafts seem solid. I didnt notice much of a play (maybe 2 mm) when I press around the center support bearing.
As far as I know, the diff fluids have never been replaced on the car. I plan to take it to the shop next week and get new fluids in both the diffs.
Anything else that could be causing this?
Thanks!
