2002 INFINITI QX4...Stalled
JBELLJR
Car: 2002 Infiniti QX4
My 2002 QX4 on highway doing 65 mph just stalled out. No misfire....No sputtering out...just quit. Put it in neutral fired it back up all was ok until I took my foot off of the accelerator.....stalled again. So I kept on the gas to keep idle higher and got it home. This morning would not start without pumping the pedal. Drove down the street and it died again. Now will not start at all. Where do I start?
PapaSmurf2k3
Site Admin
Well, it should definitely have a check engine light for that sort of thing, so I'd get an OBDII code reader and pull the code. Was it running rough or lacking power when you were driving it after the initial problem?
Welcome to NICO!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Welcome to NICO.
Try changing the fuel filter if you haven't yet - it may be completely clogged. See this thread for a guide on changing it.
Also try cleaning your throttle body and idle air control valve. Use throttle body cleaner only.
