2002 Infiniti QX4 Fuel Leak - Part Name Experts
Octillery
Car: Nissan D21 SEV6 1987
Hello Nico!
I am trying to find a name for a part on my truck.
It is part that joins the fuel filler tube to the other tube before it leads to the gas tank.
http://images.apwcontent.com/is/image/Autos/spifn749_is
I will try to get a picture of the part on my truck today.
Thank you for your help.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
The link you have shows the filler tube assembly. I had to replace mine last year (2002 Pathfinder).
Did it myself, but it wasn't that easy. Very finicky.
Is that the part you are trying to find, or is it something else?
You can try and look on courtesyparts web site for the part number.
Octillery
Hey Buzzman,
It is the part that connects to the very bottom of the filler.
Buzzman
Check page 5 of the FSM under fuel system.
Hopefully this link will work:
http://www.nicoclub.com/FSM/QX4/2002/FE.pdf
From the look of it, the rubber section that the filler assembly goes into is actually part of the tank.
I seem to remember thinking that way when I replaced my filler assembly.
The leaks are usually at the top of the neck. There was a recall on them for R50's up to 2001.
Unfortunately, the 2002-2004's are exempt.
Octillery
Hey Buzzman,
Okay I will have to figure out some sort of solution to stop the leak.
Thank you for your help!
