2002 Infiniti QX4 Bose Head Unit RGB Color Code
jjr_wi
I am replacing my 2002 Infiniti QX4's Bose Head unit and replacing it with a Kenwood KDC-X799.
The install of the radio went fine, all controls, radio, blue-tooth, Sirrius XM are working great.
But I can't seem to match the color of the display, with the green color of the display that was on the Bose unit, as well as the temperature settings area above the radio.
And in all the articles on the web about swapping out the Bose for a different unit, no one mentions the RGB color to use on a new after-market head unit where I can set a custom RGB color for the display.
Does anyone have the correct RGB color code that will match the the Bose unit I am replacing / the temperature settings display?
Any help would be appreciated!
Thanks,
Jim
fatman023
Car: 2003 QX4 - Some Chromed Canadian variant
Did you ever get close? I can't quite get a match.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
I have my 8 year old Kenwood DNX-5120 set at the following and it is pretty close I think...
However, I don't know if the numbers will be the same on the newer units.
Red 24
Green 12
Blue 5
