smithkevin wrote:One thing of note I had the oil changed at local place the they put Breat fluid in the resovor that goes into the fan. Please help.
Did this local place flush that system out and put the proper fluid back in? Is your fan operating as it should? Break fluid is a very caustic substance that can do a lot of damage to systems that aren't designed to handle it.
If your fan is working ok, I would lean toward your cooling system not being bled properly as the source of your overheating. Newer Nissan engines are very particular about following the proper bleeding procedure anytime the coolant is flushed or drained - otherwise air pockets in the system can cause what you're describing. Check out the factory service manual (FSM) at
www.nicoclub.com/FSM/ for that procedure.
Good luck!
Heath
