2002 infiniti Q45 Front LCA bushings (traction bushings)
/209JOHN\
Car: 02' Infiniti Q45
99' Lexus LS400
Does anyone here have problems with their front LCA bushings leaking fluid and clunking? I just bought my car and I am trying to find replacement bushings. I think I read some where on here that people were replacing the lca bushing with 300zx ones. However, does anyone know if the f50 and z32 share the same traction rod bushings? If so, does anyone on here have experience or know if these will work on our cars(f50)? http://www.z1motorsports.com/product_in ... ts_id=1167
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
First of all what you're listing there are tension rod bushings, not lower control arm bushings, so that won't work. I would reckon a guess they MIGHT be the same, however typically it seems cross-compatibility is an era-based thing. not always true, but it's a good mentality to have. This is why many G50 and Y33 things were the same as the Z32, R32/R33, S13/S14, etc because they were made at the same time as the Qs..
Without knowing anything specific about the F50, I would say you're more likely to find a solution with the G35 or 350Z...
It's a bummer because with Infiniti you have to get the entire rod just to replace the bushing. You're probably going to have to do some experimenting, or bite the bullet and get a new control arm. I doubt anyone has done it here, and if it's not been done here it's unlikely it's been done anywhere else (although I don't know that for sure).
/209JOHN\
99' Lexus LS400
^yeah, it was a wild shot. I am hoping other f50 owners on here have the same experience and found an inexpensive solution. Otherwise, I gotta buy new LCAs for $200.00 each side. Here's the cheapest I've found them for: http://infinitipartsonline.com/parts/20 ... ntrl%20arm
