2002 Infiniti I35 Bose aftermarket replacement speaker issue
i35beastin
Car: 2002 Infiniti I35
so today i got my new aftermarket stereo in professionally installed. i ordered the jvc xr810 reciever to retain the stock look, it has bluetooth, ush, hd radio, fully loaded, metra axxess steering wheel control adapter, nissan antenna adapter, and the metra wire harness 70 7551. after install everything worked except the bose speakers are not very loud, i turned up the stereo all the way and it sounds half the sound my stock headunit use to give, the sound you can hear and it sounds good, but its not loud enough, i have to turn the volume up all the way to make it sound good, half way up and it sounds like its on low. i know other people had similar issues with the sound being too low, do i need to get the PAC ROEM NIS2? i also have aftermarket sub and amp installed in trunk. speakers are all stock bose, headunit is a jvc. please help. thanks
C-Kwik
Only thing I can think of is the gain setting on your amp. If the output of your stock unit was higher than your aftermarket unit, the amp will just simply think its getting a lower volume signal. Turning up the gain would fix it if that is the case. Perhaps make sure the stereo isn't on attenuation mode as well.
shadowrider114
i35beastin wrote:so today i got my new aftermarket stereo in professionally installed. i ordered the jvc xr810 reciever to retain the stock look, it has bluetooth, ush, hd radio, fully loaded, metra axxess steering wheel control adapter, nissan antenna adapter, and the metra wire harness 70 7551. after install everything worked except the bose speakers are not very loud, i turned up the stereo all the way and it sounds half the sound my stock headunit use to give, the sound you can hear and it sounds good, but its not loud enough, i have to turn the volume up all the way to make it sound good, half way up and it sounds like its on low. i know other people had similar issues with the sound being too low, do i need to get the PAC ROEM NIS2? i also have aftermarket sub and amp installed in trunk. speakers are all stock bose, headunit is a jvc. please help. thanks
I have the same exact problem right now. I just had my PIONEER stereo installed professionally a few days ago and noticed the same exact thing. It's not loud at all. My stock BOSE Stereo was so much louder. The guy said that I had to get an in-line amp to make it louder? Any thoughts on this? BTW I kept my stock bose speakers as well.
ST19AG_WGreymon
Car: 1998 Infiniti I30 Base
Your head unit's pre-amp voltage is below 2v hence the low volume level. This will fix your problems:
PAC-ROEM-NIS2
http://www.pac-audio.com/productDetails ... egoryID=26
shadowrider114
Thanks bro! I'm not a DIY kind of guy cause I usually mess things up so I'll just have the guy install it for me. Thanks again!
SGiese
Car: 2016 QX50 AWD, 2008 G37S Coupe, 2007 M35 Sport. Retired: 2003 Infiniti I35, 2002 Infiniti I35, 1987 Nissan 200SX-SEV6, 1990 Nissan Sentra, 1993 Nissan Sentra, 1995 Nissan Hardbody, 1998 Infiniti I30
Looks like I'm getting ready to pull the trigger. The old stock head unit cassette deck died so my cassette adapter to MP3 player is now non functional. How's this parts list look. Anything missing?
PAC ROEM-NIS2 System Interface Kit to Replace Factory Radio and Integrate Factory Amplifiers for 1995-2002 Nissan Vehicles with Bose Audio Systems by PAC
Metra 40-NI10 Nissan Antenna Adapter
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface
Metra 99-7609G Dash Kit for Infiniti I30/I35 2000-2004 (Grey)
Alpine CDE-W265BT Double DIN Bluetooth In-Dash CD/AM/FM Receiver w/ App Direct Mode
