2002 INF QX4 Alternator replaced, now zero power
dat280zxt
Car: 1983 Datsun 280ZX-T
1991 Nissan 300ZX-TT
2001 Infiniti QX4
Confirmed my diode was out.
Bought new Alternator.
Bolted right in.
Small wire on small stud, large wire on large stud with black rubber cover, bolted bracket for main wiring harness, reseated the ... multi-plug.
Reattached the battery, and now nothing at all. First tried the remote lock since I was sitting ther*e. No lights. No headlights. No horn. Didn't risk ignition. :wtf2: :ohno:
I checked the alternator fuse. Looks good.
What order should I check what? :gotme
Any help is welcome. I owe my (so far failed) installation to Nicoclub forums in the information to get the swap process. Things were running so well... maybe you can get me the small step forward to completion.
I'll be very grateful. :bowrofl: :mike
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Probably a dumb question but is the battery dead? did you check it?
QCtech
Car: 2003 Pathfinder LE
Can you describe what the truck was doing before changing the alt?? Was it cranking? Did you disconnected the battery before doing the swap?
