2002 I35 Spark Plug Pattern
kwlowe62
Car: 2002 I35
Hello,I've searched the forums but have not had much luck.
I have a 2002 I35 with 118k miles. I'm getting a code P0305 indicating that spark plug 5 is misfiring. I've removed the intake manifold and now have clear access to all of the coils, however, I don't know which plug is plug 5. Does anyone have the spark plug layout for a 2002 I35??
Thanks for your help!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Cylinder 5 is the far right (driver side) plug on the rear bank.
Cylinder count is like this:
=Firewall= 1 3 5 2 4 6=Radiator=
kwlowe62
Car: 2002 I35
I now have a separate but related question.
I had been smelling oil prior to the misfiring that the care is now experiencing. I think this was the result of putting too much oil in the crankcase. After removing the intake, I now see that the air ports of the intake and the block are coated with oil... thus I'm almost sure that this is contributing to the misfiring that I am not experiencing. I'm wondering if there is anything that I should do, prior to replacing the plugs, coils, and putting everything back together? Should I try to remove the oil that has coated the intake ports?
