2002 I35 Spark Knock
gkellum
Car: 2002 I35
Searched for previous post!!!
Bought my 2002 I35 about 18 mos ago with 47000 miles. Noticed it had a little spark knock when under load conditions. Car now has 76000 miles and the spark knock is terrible and it seems very sluggish / hesitant to get upto speed.. Always use 93 Octane!! There are no codes displayed. Help!!
Has anyone had / and or resolved this problem?
qship96
Car: 1996 Infiniti Q45
Sure it is not a loose exhaust heat shield rattling ?
Have you checked codes to rule out bad knock sensors which DO NOT illuminate the "check engine light"?
Might want to have tech check/adjust engine timing and do a once over on basics{vacuum leaks, disconnected connectors, sparkplug condition,etc}
gkellum
Car: 2002 I35
Thanks Qship96, I'll look into it!!
Q451990
qship96 wrote:Have you checked codes to rule out bad knock sensors which DO NOT illuminate the "check engine light"?
Bet the OBDII ECU in an '02 does. Not sure though...
I would suspect carbon fouling or a clogged EGR passage - but that's just a wild guess.
Heath
qship96
OBD2 in my 1996Q does NOT illuminate check engine lamp for knock sensor codes pretty sure later{97-06Q} dont either.Easy enough to rule out by using a generic obd2 code reader either way.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
With no maintenance history provided (OCI, fuel filter ?), we are stumbling in the dark somewhat.
gkellum
Car: 2002 I35
Thanks for all the input.... I have done nothing to this car other than an alternator/ water pump and a battery. I am getting the code scanner run again tomorrow and hopefully will know more then.
fixer
Car: 08 Sentra
i have seen a lot of maf sensors go bad on your type of veh. ck with a scan tool and look at the alpha on leaf and rt bank. it shoud be around 95 - 110%. if you have pinging it would usually be from alpha being too high. if you dont have any vacuum leaks, i would ck the Mass air flow sensor/meter.
gkellum
Car: 2002 I35
I had the scan tool hooked up again today... Nothing?? I also cleaned the MAF with electronics cleaner. Not any better.
