2002 I35 Codes pulled questions
ffffly
Car: 2002 Infinity I35
hello,
I went to to autozone to pull the OBD II codes and this is what I came up with:
P0011P0021P1147
Can anyone please tell me the severity of these codes. Is it something I could handel myself or what would I be looking at cost wise if I take it to my mechanic to fix.
Any feedback would be so helpful!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
P0011 - IVT Control (Bank 1)P0021 - IVT Control (Bank 2)P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)O2 sensor locations: zerothread?id=120838
ffffly
what do the first two codes mean? Is it expensive to replace? what does it mean? ANy help you could provide would be soo helpful
thanks
maxhopper
Car: 02 Maxima SE 6spd
IVT stands for Intake Valve Timing. I've never personally encountered someone with these codes. It may be a simple matter of one of the sensors in the circuit; or your engine is off time. Here is a description of the components involved.
teksurv
Car: 1995 Nissan 300ZX and 2006 Audi A4
I recently had code 1147, and like what was mentioned on another forum, it turned out to be a tank of bad gas. There is a TSB for that code, essentially the ECU is a little to picky and it is reflashed to negate nuissance codes.
Run a full tank of another station's premium, and see if the 1147 code disappears in a couple hundered miles. You can also do the gas pedal shuffle to reset the ECU, and read future codes.
