Hdnseek »
https://forums.nicoclub.com/hdnseek-u249271.html
Wed May 27, 2015 6:42 am
*I have spent hours searching prior threads but to no avail i have not found a definite answer or suggestion to these conditions*
So i have a 02 i35 that i picked up with front end damage for 300, runs and drives, has 135K on it.
It sat for 8 months or longer before i saved it from going to a junk yard.
The frome is straightened and i welded a new front radiator support in, and in the process of finishing it up to use as a dd.
Here are the issues im having:
- I have been getting a unbarable jerking/bucking problem when i go WOT right aroung and after 3800rpm. I can punch it in first and itll pull to right at 4k strong then the power band falls off but itll rev out to redline, after it shifts into second at 4500k it starts bucking hard like im hitting fuel cut. It has started doing it in first gear slightly to around 4k. Anytime i want to punch it it has no power and rattles my teeth from the jerking. Sometimes it clears up a bit but still lacks power up high.
-Under moderate load under 3k i get what sounds like chain slapping, it goes away after it downshifts or revs past 3k, assuming im starting to get into timing chain problems but hopefuly not.
- The car idles perfect, no check engine lights, only stored code is a power steering circuit fault. Cruising is perfect, drives like new until i hit 4k and sometimes itll buck slightly when cruising.
-Going to do somemore diagnosing tonight to check mounts, maf, tps. I just flushed the trans and the problem remains persistant.
-Any suggestions to problems you have came across similar to mine please let me know. Just getting frustrated the more i dig into it.
Thanks in advance
