dudemeister »
https://forums.nicoclub.com/dudemeister-u85075.html
Fri May 01, 2009 3:34 pm
Hi there,
New poster here with a question about my 2002 I35. I replaced the rear bearing assemblies yesterday and as soon as I lowered the car and applied the brakes for the first time I heard a rattling in the front (assuming it's the ABS pump) felt the rumble in my brake pedal and then had the the ABS light illuminate as well as the TCS and SLIP lights. I plugged in my code reader and it came up with P1211 which says it's a "VDC/TCS/ABS Control Unit Malfunction".
Today I made sure that my ABS Sensor Rotor rings (the metal cogs) were pressed in and had an equal spacing with the sensor, put it back together and then proceeded to have the same problem.
Does anyone have any advice, or has anyone had the same problem? Something tells me that it's not just coincidence that this started after I replaced the rear bearing assemblies. I dont mind driving with the ABS off, but it's pretty annoying having to wait for the system to kick it off after the pump rumbles long enough.
Thanks in advance,
Rob
Modified by dudemeister at 7:12 PM 5/1/2009
