: I have a 2002 Nissan Frontier 2.4l . It spent all the time during the recent snowy icy weather here sitting. I started it regularly to keep the battery charged. Once the weather gave me a chance to I dug out our driveway and I planned to drive it to work. I made it as far as the road we live off of before it started to shudder and die. It would after that idle but would not accelerate. Now it will not idle or run at all. I have changed the fuel filter and it is pumping gas at least to the filter. But it's not getting any pressure to the test port. I have taken the return line off the pressure regulator and cycled the pump. Fuel is bypassing the regulator. My question is: should it be bypassing a large amount like it is and is that why it is showing no pressure at the test port? It isn't showing any codes other than a cat and egr code it already had. As long as I'm cranking it it tries to start.
TIA
