2002 Frontier supercharged engine cuts under hard acceleration
machine111
I have a 2002 Frontier supercharged and under heavy acceleration the engine will cut and sputter almost stallin out. When turned off and resterted it will run fine again. If you are framiliar with this type of problem or have any ideas I would appreciate your comments.
Raxephon
Car: '04 RX8...for the moment...
Welcome to NICO:)
While I don't own a Frontier, I can at least start you out in the right direction. http://phatg20.net/modules.php...d=270
Mr1der
does it do that everytime you put in under a load?
as in back off and it'll run normal?
