Davidlorang »
https://forums.nicoclub.com/davidlorang-u312642.html
Wed Jun 05, 2024 8:15 pm
Recently purchased the above truck and have been doing a lot of work on it. I’m a diy mechanic so lots of learning along the way. Truck was in need of maintenance on a lot of things. 197,000 miles on it. Long story short I replaced the distributor and plugs and wires. Timed it as per the Haynes manual. Hood sticker said 10 degrees btdc. Truck runs very well now (used to sputter and shake at lights). My issue is when the engine is cold it will fire right up (within the forst 1-2 seconds of turning over. Like a vehicle should). When the engine is warm I have discovered it does not want to start unless I turn the key to the ON position for about 3 seconds before I start to crank it over. It always starts if I do this but has to crank for 2-3 seconds. My thoughts-
1- possible fuel pressure issue? But why not at cold temps? (Replaced the charcoal canister, fuel filter, and fuel pump when I had the bed off).
2- faulty part in the brand new O’Reilly distributor? I have seen other threads on this being a possible issue but it’s brand new?
3- Some other sensor or timing issue? Mass airflow? (Truck runs well just a quirky start).
TIA
