n3t »
https://forums.nicoclub.com/n3t-u148593.html
Sat Nov 28, 2009 7:02 pm
I'm getting an idle miss and it seems like when i'm under the hood reving the tb fast it has a lag. I'm thinking it's due to the miss it's having but i have done this to try to correct it. Changed plugs, wires, fuel filter, ks, distro cap, rotor bug, changed out the injecter insulators when i had the plenum off due to the ks problem. It's still giving me a code for bank 2 catalyst below threshold and i know i have some leaks around my exaust manifold but do you think it could be causing the miss and loss of power on rev? It is sfi so i'm thinking i might have an injector problem since everything is knew on the ignition side except for the timing belt. I have thought about advancing the timing but i wanted to make sure everything else is done first.Ps, the gap on the plugs are around 40 and they are ngk iridiums i didn't set a lower gap because it's not supercharged and i have had this miss for since before the last plug change when i put bosh iridiums in there. I think bosh messed up my cat lol.
