david gussie »
https://forums.nicoclub.com/david-gussie-u55820.html
Sat Apr 28, 2007 2:49 am
Have an o4 with 28m on it. I get a tic from what I thought was the timing chain guides and tightners. Was told it is the injectors made by Bosch, german and their noisy. also, have you ever changed your transmission fluid? Note don't go to the quick fills and have them flush your system. they will damage your transmission. The power flush damages a part in the transmission. the best way is to unscrew your transmission drain plug and let it drain. add the same amount or add until it is hot and at the full mark only. don't over fill. do this every oil change it will take about 3 times untill the oil is almost fully changed. By the way is the fluid dark and smells like burnt toast, if so you go problems.Let me know what it was and or if this helps
