2002 altima no spark
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
jgumina
engine rebuild,cranks good, no spark,will start and run when i unplug cam sensor. no codes set when sensor is plugged in ,set a cam sensor code
when i disconnect sensor to start vehicle. i also swapped crank sensor
with cam sensor to see if i had them back wards.no start.installed new cam
sensor same problem.
Mr1der
can't personally help you with the problem....but I can help point you in the right direction.
first off, which engine do you have? 2.5 or 3.5?
jgumina
Mr1der
k...I'm gonna go ahead and move this thread to the Altima forum where you should get a response quick and hopefully some insight or a solution to the problem
jgumina
Thanks
Return to “3rd Generation Altima Sedan (2002-2006)”
