2002 Altima engine oil
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Knicks05
I have a 2002 Altima with about 107,100 miles. I last changed the engine oil 900 miles ago and it is already at the low level, right on the dot. Is this normal for a car to consume oil that's quick with so much mileage. Will I be fine to drive my car about 50-60 more miles before I go for an oil change or should I go ASAP? This is my first car and all insight will be helpful, thanks.
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
Any smoke out the exhaust? Smell like it's burning oil? Any noticeable oil spots on the ground after parking it overnight?
Top off the oil level and go have the car looked at by a mechanic. Shouldn't be burning that much oil, so you either have a pretty good size leak or something is going on with the engine. i.e. headgasket, rings...etc.
Throckmorton
Car: 2007 Altima
Sounds like the catalytic converter is bad, which has ruined your motor. Do a Google search, Nissan has had a lot of these problems.
bobisthere
Car: 2003 Altima 3.5 SE
Check you PCV and consider an oil catch can, the PCV design aint perfect on those cars.
Return to “3rd Generation Altima Sedan (2002-2006)”
