2002 Altima 3.5 SE Engine is shutting down P0345
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
borninabarn
Car: 2002 NISSAN PATHFINDER SE 5 SPEED
Hey All,
We have started to have problems with our 2002 Altima SE 3.5 engine shutting down turning right backing out of a parking spot.I pulled out the scanner today and scanned it and the code that came up was P0345 Camshaft Position Sensor Bank 2.First off does anyone know where exactly this sensor is located so I can check to see if maybe?the plug might be coming loose? I took the plastic plenum cover off a few weeks ago to replace a coil and I am not sure if maybe I did something then or not? My wife drives this Nissan of ours so a quick correct response would be a great help right now!Thanks,Born
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think the cam sensors are known to go bad on the 3.5's.. Bank 2 would be the passenger side, it should be on the front of the engine toward the top. You could always check the plug for corrosion, but I bet the sensor is going to be bad.
borninabarn
Thanks for the response.Yes it is the sensor towards the radiator.I have one ordered if it would ever get here(Rock auto$39 sat in LA.2 days?now in Florida? supposed to be coming to Iowa I hope)Probably should had ordered both sides and be done with them?THANKS AGAIN,Born
saparda
Car: G37s Coupe
Hi
i woke up today with the same error code P0345 for my other car , i've got the Altima 3.5 V6 2002.
sorry to ask but can you post a picture of the Sensor location!? :chuckle:
borninabarn
You cant miss it.Looking at the engine from the front to the right hand side of the engine head it has a plug on it.If you look at the rear engine head you will see the other one with the plug.You have to take off the plastic cover on the top with the 4 bolts with a torx bit 25 0r 30 I think? I got my sensor from Rock auto.They were the least expensive I could find.Orielys wanted $74.99 If you cant see it that way i put 2002 Altima 3.5 camshaft position sensor location picture and it showed a good pic.
Outkast
Car: 05 Titan 4WD CC, 00 Maxima SE 5spd, 91 TTZ
Bank 2 is the front head, it's located on the transmission side of the head with a black squeeze clip.
Return to “3rd Generation Altima Sedan (2002-2006)”
