Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Tue Jul 15, 2008 5:34 am
Ask your neighbor to let you drive the truck. That will answer your questions about RPMS at highway speed, etc.
These trucks do use gas. Expect about 16-18 mpg at best in mixed driving, assuming the truck is stock. The VG33 is a good engine despite the belt, and the service interval is 105k per Nissan for the belt. I know of no one who has converted it to a chain.
Gearing is probably 4.636:1 in the axles. You can look over the axle thread stickied at the top of this forum for all the info you'll ever need to know about Nissan truck axles, and how to find the ratio, etc.
You always want to drive the truck in 2wd unless you need the 4x4 on a slippery surface. Never drive in 4wd on dry pavement. You'll bind the drivetrain and you can break stuff. This is true 4wd, not AWD with viscous coupling that allows front and rear wheels to turn at different speeds.
