outThere »
https://forums.nicoclub.com/outthere-u291515.html
Sun Jul 07, 2024 2:18 pm
has aprox 200k miles has the RE4F038 transmission. So when the sentra starts bucking, the tach stays steady, No fault codes from ECU. I use to turn off the OD for a few miles then back on again and that would take care of the issue for awhile. now it's bucking with the OD off. At a light with the A/C on or not after a minute or two, the idle will drop slightly and the sentra will start bucking and will eventually stall. at the light when the car starts bucking if i move the gear selector to Park or Neutral all will be ok.
by default the Sentra selects OD when I start the car. is OD supposed to be always ON? or just when the Sentra gets to a certain speed?
