ndw7777 »
https://forums.nicoclub.com/ndw7777-u66673.html
Tue May 29, 2007 5:14 am
Hi everybody! First time trying to describe this problem, so please be patient.
My cd player went out last week. It would only "click" very fast, then switch to the radio. Then this past weekend, while the radio was "off" the display changed from having nothing on it to "TEL". I was not able to turn the "TEL" off, and thought I would check it out later. What I did not know, was that the display light would stay on for 2 days, and drain the battery.
Thinking logically (?) I thought if I removed the fuse for the radio amp(15), it would not run the battery down. However, when I started it up this morning, it was low. Once I got to work, I also removed the radio fuse (10a). I'm hoping this will help until I get it to the dealer.
The battery is only a couple of months old, and I bought the biggest one possible... Interstate
The bigger problem I have is with a belt squealing - whether it is hot or cold out, rainy or dry. It might be the worst noise my next door neighbor has ever heard early in the morning. The mechanic say there is nothing wrong with the belt, and they have done something with a "tensioner". I'd like to know what to tell them when I take it back.
Thanks for your help!
ndw7777
