2001 xterra AC blows cool not cold
1soxfan
Car: nissan xterra
Ac blows cool not cold I have evacuated ( alowed 1hr for to evacuate @ -29vac.) and recharged the system and cleaned the coils to no avail. Any ideas?
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Does the suction pipe sweat?Check the blend doors on the heater box.If not correct the heater core will be convect heat into the vents.
1soxfan
Car: nissan xterra
The suction line gets real cold not sweating
NM50
With the A/C off check the vents with a cheap meat thermometer.The outlet temp.should be no more than 10 degrees higher than the ambient temp.
