centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu Jul 28, 2016 10:59 pm
Doh, I just looked at the listed years and it's older than yours by a year or so. It may be worth trying anyway. I used it on my 240sx. It's easy because you just set the on - off side of things instead of reading the ohms or volts on the other side. That part is useful for diagnoses of the tps if you have odd throttle behavior. I din't use a feeler gauge, just had the continuity off, pedal up, twist the tps by hand until there was continuity, then tighten it. Somewhere around wot I think you would get continuity again on the other side. Then start the car and test it. You might have to adjust the idle a hair again.
