ezb57e »
https://forums.nicoclub.com/ezb57e-u238040.html
Mon Aug 04, 2014 6:48 pm
I think you have a oil supply problem as I described above.
The cam timing control system relies on oil pressure for a motive force.
If the oil pressure is low or of poor volume, the control valves don't have enough to send to the cam sprockets, and they can't respond correctly.
The sensors see this lack of response and can set a code.
The front cover has to come off to see the broken gasket, but I kinda think you are at that point.
Other blockages in the oil system are possible but rare, especially if the car has had good maintenance, and can be a major problem to resolve.
By looking at the underside of the oil fill cap or into the valve cover, you can sometimes get a sense of the interior condition of the engine.
Good luck
