2001 Sentra GXE - no ABS?
Forkster
Hi everyone,
I thought the 2001 Sentra GXE had ABS. Wheels lock up good - so, was it an option for the GXE and my grandmother didn't buy it? I thought it was standard, along with airbags. Anyone else have insight? Appreciate any knowledge share...
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ABS is not standard on that model.
2001 Nissan Sentra
Braking is provided by a power-assisted front disc/rear drum braking system on XE, GXE and CA models and 4-wheel discs on SE. A 4-channel/4-sensor Anti-lock Braking System (ABS) is optional on GXE and SE models. Anti-lock brakes and side-impact air bags are a smart buy at $699 for GXE and SE.
You should have an ABS light on the dash at startup if you have ABS.
sk47
Car: 2001 Nissan Sentra SE
Hello; Rogue one is correct. My 2001 Sentra SE does not have ABS. It may seem odd, but as the car and I get older I am not concerned. For one thing I have been driving most of my life without such a system so have some practice. The other is my brake system will be simpler and less expensive to repair.
Forkster
Thanks for the responses Rogue and SK. I don’t see an ABS light when I turn on the car, so I have my answer.
Grandma cheaped out. :biggrin:
It’s a great little car!
