2001 SC Frontier-knock sensor
cra034
Car: 2001 Frontier Crewcab 2wd SC
Okay, I have read a lot of treads and spent dollars, here is my problem:
2001 2WD Crew Cab SC Frontier, recurrent knock sensor code, engine light on. Once went off by itself. Have new wires, plugs, air filter. Truck runs strong, except MPG about 12-13 average. Any ideas, thanks.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Knock sensors are chronic problems for your engine, they all seem to fail. The sensor is in the worst spot and gets cooked all day long, it's only a matter of time before they fail. The SC engine loses so much power because of this, the NA not so much. The solution I am planning on after doing some internet reading and visiting www.nicoclub.com/FSM to download the Factory Service Manual I will attempt to relocate and bypass the OEM knock sensor using a Maxima sensor and some wire splicing into the engine harness. The different style sensor that can be mounted on top of the intake manifold, wired up and be reliable from that day forward...also easier to replace if it happens to fail again. I have a inactive knock sensor code on my 02 Frontier which I would like to fix soon, this Spring perhaps.
cra034
U mean there's more power to be had? cool, I will look into that.
Mahalo, Rev
brightstar
Car: 2001 QX4
338,000 miles and counting !!
Hello , I am curious did the maxima sensor work ?
I have a 2001 qx4 and my knock sensor connector broke,
need to wire up a new sensor ,
any help is appreciated
carldu
Car: 08 Titan
Don't forget to check the vacuum lines if they are hooked up properly.
