I drafted up a reply on my phone earlier, but I got signed out before I could submit it. I rewrote everything as best I can, but I apologize if it's a little scatterbrained.
VStar650CL wrote: ↑Tue Mar 29, 2022 9:03 pm
It's a locomotive drive on the QX4, there's nothing to align or adjust except having each arm on the correct side of the center pivot.
That's what I thought too, but I was unfortunately mistaken. The proper cycle of the wiper blades is just as dependent on the correct alignment of the linkage to the motor as the wipers are, because the motor has a fixed home position. If it's not connected in the right orientation, the wipers will always park at the wrong point in the cycle, even if the wiper motion is right. If both the motor-to-linkage and wiper-arm-to-linkage connections are aligned wrong, you can end up with some very ugly wiper movement.
Fortunately, it was easy to fix.
For anyone who searches for and may stumble across this thread in the future, here's how to replace your wiper motor on your R50 Pathfinder, and, if necessary, correct both potential wiper alignment problems.
1. Wiper arm alignment. If you haven't started yet, don't remove the wiper arms or the cowl. You don't have to - there's no access panel, and it's far easier to replace and time the wiper motor to the linkage if your wipers are already in the right place.
But if you already removed and/or messed up the alignment of the wipers like I did, you'll need to fix that first. It's actually pretty simple. If you didn't, look at step 2.
First, remove your wiper arms to make sure they don't hit anything. Then you first need to get the motor to cycle the linkage to it's most retracted point. Since that wasn't my park position any longer, I used painters tape to make a little flag on the spindle and turned the ignition off when it got to the end. Now reinstall your wipers in the correct position, and make sure to test them.
If they sweep the correct region of the windshield - it does not matter when or where they park - you can move onto the wiper motor alignment. If it's wrong, you may make adjustments as needed.
2. Wiper Motor Replacement and Alignment.
To realign (or replace) the wiper motor, you'll first need to unbolt it from the firewall (4x 10mm bolts), and remove the 14mm nut that holds the motor to the linkage. A box wrench works best here, but you'll need to find a way to keep the linkage from spinning to loosen and tighten it.
If you're just adjusting the linkage, the threads on the spindle are long enough that you can disengage the splines without completely removing the nut. This will save a lot of heartache because it's a little awkward to thread the nut on - there's not a lot of room for your hands. If you have to replace the motor, also keep this in mind when reinstalling it. You don't have to have it exactly right when you first put the nut and washer on. You can align it after you get the threads started.
When you have the motor disengaged from the splines, you'll want to turn the wiper motor on and let it return to its parked position in the cycle. Now manually move the wiper blades and linkage into their parked position, connect the linkage to the splines on the motor, and tighten the nut down.
If you're lucky, you can bolt it up now and it'll work perfectly. I was a tooth or two off the first time, so I had to loosen the nut and adjust it once more to get it to park exactly at the end of the cycle.
If your wiper arms were properly aligned before you replaced the motor, congrats, you're done. The wipers will sweep the exact same region of the window as before, but when the motor is aligned, they'll also park themselves at the right place.
