ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Tue Jul 12, 2011 10:53 am
12-6 vibration, could be: lower ball joint, upper strut tower.
With front raised use a 5' pry bar and lift the wheel assembly while feeling the top of the strut tower for movement within the hood, hood up of course
9-3 vibration could be tie rods outer.
Rotor and wheel assembly will indicate nothing. Check calipers, brake pads in and out of car
Check CV joints, all suspension links with bounce of car, leverage with tools, even pipe wrench or large water pump pliers.
While driving check for thuds, bumps, clicks, toe in, camber, pulls to steering wheel. Check torque on no load steering wheel, creeks and noises lock to lock
Check tires and shocks for wear, scuff, shocks are noisy when weak.
