2001 QX4 Tire Size
alinski
Car: 2017 QX80, 2008 M35, 2001 QX4
Purchased a used 2001 QX4. Came with 245/65-17. According to tirerack.com, optional 17" tires are size 255/60-17.
Which one is correct? I will need to replace the tires at summer's end and want to make sure they are the right size. Probably will be getting the Michelin Cross Terrain SUV tires as replacements.
Thanks, alinski...
SmithSR
Car: 240sx
They are both correct. Your vehicle placard(usually found in door jamb) will tell you what OEM size was on your exact unit. An automobile often has a couple of sizes available for different trim levels, option packages, etc. Both sizes you mentioned have an overall diameter within 1/2" of each other....hardly noticeable when payload, air pressure, tire wear come into consideration.
The 255/60-17 will be pitched to you as the "sportier" tire....while the 245/65-17 will be taller and more "utilitarian" according to tire sales sharks.:D
Have fun and be sure to pay CLOSE attention to price difference between the two selections.
-Phil
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
SmithSR you are correct sir! You are looking at only about 3/10" diff. in O.D. (less than you wear down on the stock tread). It's just a little wider footprint.
alinski
Many thanks for the replies. Glad I found this board.
Grant@tirerack
If you do decide to order from any of our board sponsors, be sure to use the link to that sponsor's website here on the board. They all keep track of that and it helps support the forum here:help
Exar-Kun
Car: 2005 350Z
also, send me 10 dollars.-chet
Grant@tirerack
'tire sales sharks' ? I resemble that remark!:pface Kinda reminds me of my favorite line in The Family Man is "I sell tires: retail." Hey, we all have to make a living right?
