2001 QX4 TCC solenoid replacement question
2001qx4guy
Can someone please tell me if the TCC solenoid (also known as the solenoid assembly -lock-up) can be replaced by removing only the transmission filter or does the whole control valve body need to be removed also?
Thank you.
attofarad
Car: 2001 QX4
Seems to be. Page down to the photo, with what I think may be the TCC, circled in red, and read the post that it is embedded into.
http://x.nissanhelp.com/forums/pathfind ... verse.html
2001qx4guy
Thank you thank you. Searched all over but never saw this thread. Its exactly what I need.
attofarad
Car: 2001 QX4
2001qx4guy --
How did this work out for you? My wife's 2001 QX4 is having intermittent times when it doesn't shift into overdrive. As in yours, when it is revving to high when cruising on the highway, the O/D button has no effect. Then it will be good again. Only happened a few times to me so far, but I don't drive it that often and she doesn't notice that much.
Thanks, Gary
