2001 QX4 smokes
Red365
Car: 2001 Infiniti QX4
I have a QX4 that smokes white at times, it might go three or four days without smoking, and then it will start smoking. The smoke only occurs on start up, it clears up while driving. Does anyone have any ideas?
Slumpert
Car: 1997.4 Pathfinder
First real check would be to have a compression test done on all the cylinders. Bad valve guide or piston ring is my guess.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
White smoke usually indicates a coolant leak, like a head gasket maybe.
If it's oil, it would be bluish.
Could be nothing more than condensation burning off, or it could be serious (like the head gasket).
Check your oil level and consumption, and also check your coolant level, for starters.
