AU Qx4 »
https://forums.nicoclub.com/au-qx4-u282066.html
Mon Mar 19, 2018 4:49 pm
This is my first post on this forum, but I want to thank you all in advance for this valuable resource. I have fixed sooo many common problems with the tips and tricks posted hear.
My next project is to change the rear main seal by dropping the transmission and inspecting the area to determine if it is really the rear main seal or the rear oil pan gasket. I have read other say that if you are leaking when parked then it is the oil pan, however I park on a driveway with an incline and it does leak less when I back it in but it still leaks a lot. If it looks like a flow from the crank seal I can simply remove and press a new seal in without disturbing the pan seal.
My question for any Nissan mechanics or experienced motor heads out there, is: If I do need to pull the seal retainer, is there any way to install the new retainer rms/pan seal combo without dropping the pan?
If not, is it possible to loosen the rear 4 to 6 upper pan bolts and insert a plastic shim to gain clearance for the new seal/sealant?
The FSM has you disconnecting everything from the steering column and motor mounts, to dropping the suspension member and lifting engine from above. (which I might have to do any way to rock the engine back for access to the upper bell housing bolts) All this to drop the oil pan.
